NISSAN manual (Terano, Patroll ir t.t.)
  • 1 metų...
  • po 2 mėnesių...
  • po 4 mėnesių...
22-05-09 - 2.1
* Added tip After/During an Engine Rebuild.
* Wheel Terminology formula re-write - just didn’t make sense, does now.
* Earthing Issues
* Speedo Correction
* Cleaned up some text to make more sense in some paragraphs
04-05-08 - 2.0
* Added Tyre terminology
* Added Wheel terminology
* Bubbling Dash
* Winch Considerations
* 5th Gear Failure GU
* Flat Mirror on GU4 (non convex)
* Free Wheeling Hub Diagrams - Manual
* Keyless Remote - Reprogramming
* Trailer Wiring Diagrams
* Mass Airflow Sensor (MAF)
26-11-07 – 1.9
* Restructured to find info easier
* Added section on oil pressure switches
* Added PCV Valve section
* Oil Pressure Sender install
* Oil Catch Can – How To Make Your Own and Install
* Removed the advanced and Expert Turbo 102 & 103 sections
25-9-07 – 1.8
* Added other tyre wear factors
* Added maintaining your tyres
* Updated air filter sections
* Updated thermal fan section
* Added stereo wiring diagrams section
* Added sway bar extension bracket section
3-9-07 - 1.7
* ZD Engine Protection – Oil Catch Can section - Updated
* How To Test If Your Vehicle Is Affected By Over Boost – Updated with new findings
* Why Synthetic Oils are Superior
* GU Drivers Seat Movement
* Steering Castor Correction – After Lift (added technical explanation)
* Intercoolers
* Air Filter Test Report - Spicers Iso 5011 Duramax
* Credit given to those who supplied info, well those I could remember or find
13-8-07 - 1.6
* Additions to Brake Proportioning Valve and EGR.
9-8-07 - 1.5
* Some major additions and changes to the PDF including a big section on Diesel Performance chips.
Redagavo Mikas123
  • po 3 mėnesių...
  • po 5 mėnesių...
  • po 5 mėnesių...
  • po 4 savaičių...
  • po 3 mėnesių...
  • po 5 mėnesių...
  • po 8 mėnesių...
  • 1 metų...
  • po 3 mėnesių...
  • po 9 mėnesių...
  • po 2 mėnesių...
  • po 7 mėnesių...
