JC uzsidega check engine kai gaza daugiau nuspaudi
turcinas
Susiduriau su niuansu kuris nelabai leidzia nakti ramiai miegoti.
Maniskiam 2,5 dyzeliniam VM, kai vaziuoji ir nuspaudi gaza daugiau nei puse eigos - uzsidega check engine. Ir taip visada.
Nuskaicius klaidas - meta kad throttle position sensor voltage over 4,96 V. Ir net nezinau kur cia makaronu ieskoti.
Bandem pasukioti Bosch gazo padeties davikli ant siurblio virsaus - jokio efekto.
Gal kas numanot ka?
code means that the the car's computer has detected that the TPS (throttle position sensor) is reporting too high a voltage.
Symptoms
Symptoms may include:
  • Rough idle
  • High idle
  • Surging
  • other symptoms may also be present
Causes
A code  may mean that one or more of the following has happened:
  • TPS not mounted securely
  • TPS circuit short to ground or another wire
  • Faulty TPS
  • Damaged computer (PCM)
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, carefully inspect all wiring and connectors that lead to the TPS. More than likely the problem is with the TPS wiring. Check the voltage at the TPS (refer to a service manual for your vehicle for this specific information). If the voltage spikes or is too high (over 4.65 volts with key on, engine off), then that is indicative of a problem. Carefully trace each wire from the TPS wiring harness to check for breaks, rubbing against other components, etc.
