Klaustukas
Projektas - JGC WH gamyklinės audiosistemos pakeitimas
Ta skyle paliksi ar kazka desi? :D
skylės klausimas bus sprendžiamas kada bus aišku kokia magė apsigyvens galutiniame rezultate, o jei liks 1 DIN, tai skylei užkišt turiu Clarion 920EQ-R (pajungčiau kaip vizualinį spektro analizatorių) arba atsisiūsiu iš aliko kažką tipo
 https://ru.aliexpress.com/item/2-VU/32845258857.html?spm=a2g0v.search0104.3.73.1f901f464eyxRf&ws_ab_test=searchweb0_0%2Csearchweb201602_3_10065_10068_318_319_317_5728815_10696_450_10084_10083_10618_452_535_534_5025912_533_5723512_10307_10820_532_10821_10303_10302_204_10059_10884_323_10887_100031_320_321_322_10103_448_449%2Csearchweb201603_55%2CppcSwitch_0&algo_pvid=56c52ef5-365f-41a4-b544-883c93251342&algo_expid=56c52ef5-365f-41a4-b544-883c93251342-13
https://ru.aliexpress.com/item/SD-318M-Panel-VU-Meter-500uA-640Omega-115x53mm-with-Back-Light/32608036402.html?spm=a2g0v.search0104.3.1.25607ab0iAxUGj&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_318_319_317_5728815_10696_450_10084_10083_10618_452_535_534_5025912_533_5723512_10307_10820_532_10821_10303_10302_204_10059_10884_323_10887_100031_320_321_322_10103_448_449,searchweb201603_55,ppcSwitch_0&algo_expid=7721fe56-666b-425a-9890-16a1277fae6b-0&algo_pvid=7721fe56-666b-425a-9890-16a1277fae6b
https://ru.aliexpress.com/item/VU-meter-DB-Level-Header-Amplifier-chassis-Audio-preamp-Backlight-P-59WTC/32278561978.html?spm=a2g0v.search0104.3.192.1f901f464eyxRf&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_318_319_317_5728815_10696_450_10084_10083_10618_452_535_534_5025912_533_5723512_10307_10820_532_10821_10303_10302_204_10059_10884_323_10887_100031_320_321_322_10103_448_449,searchweb201603_55,ppcSwitch_0&algo_expid=56c52ef5-365f-41a4-b544-883c93251342-31&algo_pvid=56c52ef5-365f-41a4-b544-883c93251342
:salut:  :salut:
Edited by Klaustukas
savaitgalio darbas
2 ausys gerai, o 4 geriau  :D
kiekvienas girdi kad yra blogai, bet labai labai retas gali pasakyti kuri vieta yra blogai  :scratch:
pasisodinau į mašiną draugą, kuris jau seniai sėdi ant buitinės aparatūros, ir muzikoje klausosi jau nebe muziką, o atskirus garsus (tai problema daugelio kurie "nuprotėjo"  iki "Hi-End"  :D  :D  )
rezultatas - aukštadažnių stiprintuvas nukeliavo į lentyna su perspektyva galbūt kada nors restauruotis  :D  nes vienas kanalas (tolimesnis) daugiau kraipė ir triukšmavo negu grojo.........
į jo vietą atsistojo kitas iš lentynos ištrauktas alpine stiprintuvas, bet prisiėjo pakeisti visą maitinimo, remote ir linijinių laidų instaliaciją..... vėl visa diena darbo.....
bet užtat beveik dingo zyzimas, atsirado daugiau oro ir detalumo muzikoje (aišku reikėjo ir perreguliuoti kai ką)
garsui deja tai ne viskas, nusimato vis dėlto podiumų su išvertimu darymas vidurinio dažnio garsiakalbiams nes yra parazitinių atspindžių nuo stiklo.....
bet tai vėliau, dabar užsiimsiu aušinimu nes atkeliavo pirma ventiliatorių pora  B)
Man atrodo jieškok kokia sena procesorine galva ir viskas bus super,aš kolkas nelabai ka randu geriau,aišku norėčiau išbandyt pionneer 99,bet ta jo kaina ........
Jau stovėjo pioneer 99 (nuotrauka praeitame puslapyje), tik senas modelis, procesorius man nepatinka nes iškraipo garso naturalumą...... O alpinai F1, pioneeriui ODR, sony XES ar clarion X mano likusieji sistemos komponentai per prasti.....
savaitgalį buvo ne iki muzikos - vėl pavedė liuko drenažas, ar užsikimšo, ar sulūžo nuo senatvės (ekologiškos plastmasės jopt), tai šeštadienį mašinai nuvažiavo stogas  :D  :D  ir vietoj gamyklinių vamzdelių atsistojo daržo laistymo šlanga  :P
darbo vienam su parūkymais ir kavos gėrimu užėmė apie 6 valandas.... žiūrėsim ar padės, pakolkas neteka, nors ir lietaus kaip ir nebuvo stipraus
padariau prie to pačio papildomą sujungimą galiniam myžtukui kad papildomo stopo nelupinėt stogą nuimant
kadangi pakolkas atėjo tik 2 kūleriai, padarytos skylės visiems keturiems, o pirmi du pajungti pūtimui (kiti du bus ištraukimui)
aišku orui reik iš kažkur pakliūt - išpjautos skylės atėjimui iš šoninių apdailų, kurios turi ventiliacijos groteles
ir kadangi buvo pastebėtas (klausant kai kuriuos kūrinius) durų apdailų barškėjimas, buvo padaryta visoms 4 durims  vibro - triukšmo izoliacija
pradėjo sena alpinkė per dažnai žagsėt klausantis kompaktų, todėl išvažiavo techninei profilaktikai, o jos vieton nuo lentynos paimta ir pastatyta kita alpinka kad kažkas grotų tuo metu  :)
ups kiek pirštų ant objektyvo  :blink:
magę pakeist minučių darbas, o savaitgalis atiduotas rimtesniems dalykas - nusibodo klausytis piktybinius atspindžius nuo stiklo ir todėl buvo nuspręsta šią problemą tvarkyt kardinaliai - vidutinių dažnių garsiakalbiai atsistojo į pagal juos maždaug parinktą tūrį ir nukreipti ten kur jiems  maždaug priklauso, prie to pačio ir aukštadažnius pareguliuojant pagal kryptį. Bostono sistemos gamintojai šituos reikalus spėju sprendžia skaitmeniniu būdu - dsp ir ekvalaizerių pagalba  :P
 VD garsiakalbiams sumontuoti buvo paimtos (nuo lentynos  :D  ) pionieriaus TS-X1 kolonėlės ir panaudoti jų korpusai  :salut:  proceso nefotkinau nes viskas daryta laikinai eksperimentams  :)
ir pagaliau mašinoje užgrojo taip kaip norėjosi  :liux:  :salut:  :cheer:
jei ne tikslas padaryt viską gražiai, taip ir palikčiau nes atsirado noras perklausyti iš naujo visą savo diskografiją, realiai nesinori net iš mašinos išlipinėt  :D
gaila kad dėl skirtingų komponentų jų lygiai susivienodina tik gerai garso užmetus, bet vistiek klausoma važiuojant kai tyliai nieko nesigirdi  :P
dabar butų visai neblogai kažkur rasti eksperimentų darbams viršutinę paneles dalį, kurios nebūtų gaila sugadint, ir stojkių apdailas tam pačiam tikslui  :salut:
Nu skaitau tai man čia kažkoks kosmosas. Labai norėčiau paklausyt. Super darbas.
savaitgalis praleistas prie bergždžių darbų - kažkur dinginėja garsas iš aukštadažnių, todėl buvo paskirta diena tos problemos paieškai
kadangi dingus garsui aukštadažnių stiprintuvas nemeta "protection", tai bėdos buvo ieškoma pradiniame stiprintuve, kurių mano sistemoje 3 - magnetofone, aktyviame filtre ir  pačiame stiprintuve
todėl buvo pakeistas magnetofonas (vėl pastačiau 99 pionierių), ir pilnai išrinktas aukšadažnių stiprintuvas bei jame perlituoti absoliučiai visi kontaktai ir sujungimai
Rezultato teigiamo nėra.........
bandysiu kitą savaitgalį pakeist stiprintuvą (senatvė gal savo pokštus mėto) , bet lentynoje kaip ir nebeliko dvikanalių.......... ir vėl perdarinėti dėl to instaliaciją....... mintis yra gal pastatyt šešiakanalį visai sistemai............
šį savaitgalį sumontuoti paskutiniai du aušintuvai, ir toliau vyko paieškos darbai kur dingsta aukštadažniai.....  vėlgi pilnai išrinktas ir perlituotas elektroninis krosoveris, bet tai rezultato nedavė (arba davė perspektyvai nes įtartinų vietų jame buvo pakankamai  :D  ) bet lygtai priežastis jau gana aiški - vieną iš turimų akštadažnių reiks mest lauk (nes tokio tipo plėvelinai deja yra netaisomi), ir keist dėl to reiks abudu nes dar vieno tokio deja lengvai Lietuvoje nerasiu. Reiks pasižiūrėt ką iš aukštadažnių turiu lentynoje, bet čia jau kito savaitgalio užsiėmimas.....
nu projektas vis dar tęsiasi  :D
praeitą savaitę pakeisti aukštadažniai - rasti ant lentynos šilkiniai DLS, pajungta, pasivažinėta, pasiklausyta........
deja šilkas ne man (o gal ir ne mano amžiui), po Infiniti plėvelinių šitie kažkokie ne tas.........
todėl šį savaitgalį nuo lentynos paimti metaliniai (o gal aliumininiai, o gal titaniniai - negaliu pasakyt, modelio tikslaus nežinau nors panašiausi į TN45 titaninius ) ir sumontuoti kiti aukšatadžniai, prie to pačio gražintas iš techninės profilaktikos atgal "Alpine", pakeistas aukštadažnių stiprintuvas į bile kokį pasibandymams (nefotkinau nes įkišau be korpuso, tik plokštę su radiatoriais nes kitaip netilpo o perdarinėt pabandymams patingėjau), taip kad pasivažinėsiu, pasiklausysiu.........
ir dar savaitgalio darbas - uždemferavau keleivio durų valdymo bloką nes barškėjo  :D
vairuotojo blokui pritrūko bitumo, reiks tai padaryt papildžius atsargas  :salut:
Cia tos ant priekines paneles dideles kolonkes ir liks?
jei liks, tai bus integruotos giliau į panelę kad vaizdo neužstotų (paieškoje panelė eksperimentams, gali būt iššaudytu airbagu) o dabar ten tik bandymas nustatyti reikiamą tūrį, formą, kryptį ir gal net ir garsiakalbio tinkamumą........ bet geriau paliksiu taip negu sukišiu  - paslėpsiu į gamyklines vietas  - nes gamyklinės vietos su gamyklinėmis kryptimis ir tūriu (teisingiau jo nebuvimu) yra visiška tragedija ir ausų vėžys  :D
vėl savaitgalio darbas - pakeistas (jau ketvirtas lygtais  :D ) aukštadažnių stiprintuvas, kadangi ant lentynas jau visi dvikanaliai pasibaigė, teko pasinaudoti skelbiu.lt paslaugomis - popigiaja ("nes kam reikalingas toks mažas šiais laikais"  :lol: ) nupirktas senovinis bet ledinio stovio stiprintuvėlis ir sumontuotas vėl keičiant beveik visą instaliaciją....... ir likęs laikas praleistas klausantis visokių tame tarpe ir testinių kompaktų bei reguliavimas
iš vakaro kaip ir viskas buvo gerai, iš ryto trūksta aukštų ir per daug žemų........ :scratch:
senatvė gal jau.......
duodu iš ryto visai aparatūrai apšildymui  prasigrojimą ant nedidelio garso, tik po to užsimetu watų  :D  motorą gi irgi nedusinat dugnais kol šaltas  :pig:
kad negalvotumėt kad nieko nevyksta - per savaitgalio vieną dieną (tiek šeima leido pabėgti  :D  ) buvo nuimtos, išrinktos, uždemferuotos ir pripildytos sintepono, po to surinktos ir pastatytos atgal į laikinas vietas  vidurinių dažnių garsiakalbių laikinos dėžutės   :scratch:  nes lygtai buvo įtarimas kad jos gali truputį baubti ir vibruoti...
ir tai užėmė visą dieną
